phresh
which sub setup is the loudest of these choices?
Im trying to find out which sub setup would be the loudest. All these subs have good enough sq for me. Im trying to stupid loud but only have 6cuft to work with and my amp is a sundown 1500. I dont want to use more than that in my trunk. All of the choices below are for the max recommended ported box specs. It will go in the trunk of a tahoe. The box & port will face the back. Tell me if theres anymore info you need. I want explanations also.
-1 BTL15 in a 5cuft box
-2 BL12 in a 5cuft box
-2 SSA Icon 12 in a 5cuft box
-2 Alpine Type-Rs 15 in a 6cuft box (cheapest)
I also have three other choices but lower than the max ported box specs. Im sure it wont be that big of a difference in a smaller box. If it makes a big audible difference i could go to 8cuft for either of the choices below.
-2 SSA Icon 15 in a 6cuft box
-2 BL15 in a 6cuft box
-1 BTL18 in a 6cuft box
Right now i prefer the type r's out of everything. Any one now any numbers on the type r's as well?
THANKS!!!!!!!!!
What type of car do you have that will allow you to slide 6-8 feet in your trunk opening. Is this net or gross area?
A tahoe
ohhhh, k that makes more sense. I would do the Icons. Naturally the 15's would be louder than the 12's and it would only run a little bit more $$$
Edited by Audibel Customs
i'm leanin towards the 2 15" icons. that's if you want insanely stupid loud. but that will give you pretty good music too.
if you don't care about how it sounds too much, go 2 15 BL's. either way you'll be really happyyy
So 2 Icon 15s would be louder than 2 BL15s on a Sundown 1500?
So 2 Icon 15s would be louder than 2 BL15s or a BTL18 on a Sundown 1500?
I say 2 15" BL's in 8 cubes on two SAZ-1500D's
I just removed the YELLING from your thread title. Don't ever post one in all caps again.
If you are worried about peak output, the BL's are designed to have more peak output then the Icon's. I would love for you to buy Icon's, but I am not going to lie to you for it to happen. ;)
X2!
x3
I Say Two Fi BL 15"s. (Even The Fact That I Am For Sure Switching To Cascade Designs, I Will Always Be Behind Fi/AA 100%, And At Least One Of My Vehicles Will Run A Fi/AA Product For That Reason, Great Subs, Great Customer Service, Bottom Line.)
