lolitskasey
Box help
So i was trying to look for some pictures of a box terminal made out of ring terminals, nuts , and bolts. So i can have a idea on how to do it.
Thanks.
no pictures but i'm sure this will help
...... Don't buy terminals, get some bolts, nuts, and some ring terminals and you are set. Drill two holes in your box, one for (+) and one for (-), make sure your bolts are just small enough to fit in the holes, attach a ring terminal on the outside, one on the inside, and put the nut on. You are set, you can put some silicone around it if you are worried about air leaks.
Edited by kayone707
One on each side of my box .
Leave enough slack of wire to where if you need to remove your sub , you can easily set it ontop of the box and unhook it .
Positive +
Negative -
Edited by Joker
no pictures here either, but i went to the local fasteners supply place and bought 2 2 inch long brass bolts with nuts and washers. worth the 10 imo
