panky
saz1500d on a bl
can i max the gain on the saz1500d without breaking the bl? is 1500wats the max wats that a bl can handle? or can it handle a little more? and what can a saz1500d really produce? coz i know its under rated, thanks!
You should never max the gain on any amplifier regardless of the driver. The BL can be safely used with the SAZ-1500D if you are smart with gains and don't push the amp into clipping. The 1500D's have been tested show upwards of 1700 watts on a stout electrical system.
and 1700 is too much for the BL. daily.
same setup i have right now just got it in 2 days ago. everything sounds good to me
True, mine do 1800 rms a piece at .5 ohms and I don't even have the gains maxed out.
From expierence the BL's WILL take a 1500d full tilt. I use to run 2 15" BL's of 2 Sundown 1500ds! I could wang them ALL day long. They would get hot but I never really smelled any coils. My voltage was down to like 11.7 to.
