eric77
It FINALLY arrived!
Yes, after an ENTIRE day of waiting it arrived :P Don't you jsut hate those long waits.
I can't wait to get it installed and finally hear what it sounds like. All I know so far is that it is sexy as hell and soundsplinter has the best customer service ever.
ohh
me likee...alot
That signed cone looks neet-o
I have to agree 110% with that FACT
Been there, seen that  :P
You best be showin' us pictures of your install too!  :woot:
Don't worry, I will. It might help to build a box first though. :P
On that note, I am planning on building it tomorrow. I have access to a table saw but it is in a smalll workshop and has been modified to only accept smaller pieces so I may need to have the wood cut at home depot and then fix them on the table saw if they are off.
that sig is going to make for some sweet porn!!!
i told y'all mike has the best customer courtesy hands down!!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
Should I use a double 3/4" baffle on the box? The sub weighs about 35 lbs. Thanks.
I decided to use a double baffle and flush mount the sub. Befor I get started can somebody double check my cut list? HEres the box 2.gif
Heres the cut list I came up with. BTW, I added 3/4" to the top, bottom and sides to account for the double baffle.
(2) 17 1/2 x 16 3/4 (Sides)
(2) 28 3/4 x 16 3/4 (Top/Bottom)
(2) 26.45" x 16 3/4 (Double Baffle)
(3) 12 1/2 x 16 3/4 (Port Walls)
Forgive me if I'm a little hazy this morning.. just woke up!
Since the gross height of your box is 17.5", I think your port walls should be (17.5 - .75 - .75) = 16" high?
On your diagram, the top of your box is labeled as 16" max width, so I think your side pieces should only be 17.5" x 16".
Also, I don't see a piece listed for the back side of the box. You'll probably need one of those wink2.gif = 28.75" x 16"
It looks like your front baffle piece should be 26.45" x 16" and the reinforcement piece should be laid on top of that at 27.2" x 17.5" - as not to affect the internal volume of your enclosure.
This correlates to the following:
  • (2) 17.5" x 16" (Left/Right Sides)
  • (3) 28.75" x 16" (Top/Bottom/Back)
  • (1) 26.45" x 16.75 (Inner Baffle)
  • (1) 27.2" x 17.5" (Outter Baffle)
  • (3) 12.5" x 16" (Port Walls)
I hope I didn't royally fudge those numbers.. :ohsnap:
I realized those numbers were off and I came up with these. I think we are going by different assembly methods. I just assumed i would piece everything together as it is in the picture. Do these new numbers look okay?
(2) 26.45" x 16 (Double Baffle)
(3) 12 1/2 x 16 (Port Walls)
(1) 28 3/4 x 16 (back)
Also, I added 3/4" to the sides, top and bottom so that i could fit in a double baffle w/o affecting internal volume.
Well, I'm off to get the wood and make the cuts. Im going to use these numbers because they seem to make sense to me. Hopefully I'm not off. If anyone notices that i completely f'ed up within the next 30 minutes or so give me a call (949 295 5897) so I dont destroy my box.
Indeed, I was giving you numbers that would've allowed you to mount the front/outside piece of your double baffle on the outter sides of your top/bottom/side pieces on the front of your box. Your new numbers will allow the side pieces to extend out an extra 0.75" in the front for the double baffle to be mounted inside the top/bottom/side pieces, instead of outside like I had imagined.
In short, your numbers seem to be spot on! :woot:
The box is complete and it is damn near perfect as far as looks go. Who knows if it will sound good but it looks f*ckin awesome.
I can guarantee that you have never seen more perfect circles than the ones I cut, or rather that the computer cut. :D
Details and pics will come tomorrow.
