BoomBoxB
Screwless Box
"glued only" boxes are a lot of fun though ,
I say go for it !
aplying the right amount of pressure is a big thing when glue is dryng ,
the glue I use needs 2,5kg per cm2 minimum and a good room temp .
I wouldnt recommend D4 glue (the kind that foams up)
rather a white D2 woodglue that dries up transparant ,you'll need a thight fit for it but will be a lot stronger
ok box came out great, only used about 20 screws, (it was cold) came out great no leaks, and strong as hell. proper bracing was installed, and went smoooooth.
and let me tell you.... its loud!
:ttiwwop:
hahah well i think it will stay worthless, i just go on here while im at work, and have no access to pics. :mellow:
we have different model xbs anyway your trunk is way bigger, but do it man you wont be disappointed.
Your ported box doesn't leak?
no not at all, i used wood glue and then silicone caulk for all the seams...
