treylittlefield
electrical upgrade :)
Make sure to do the big 3 when you put the new alt in, otherwise youll be wasting your money.
Your electrical isn't dependent on what subs you're using....What amp are you running?
sounds like you are doing everything you should be to run that amp properly. I'm sure you are, but make sure to read up through the sundown forums on that amplifier, sundown amps are great, but to make sure you get everything out of it and to be sure it is installed 100% properly I would say learn everything about it that you can.
Where would i find a forum for it at??
scroll down on main forum page...lol
It hasn't been released yet (mid May is the ETA I believe.)
Get in touch with "sundownz". He should be able to help you out the most.
yeh sundown audio is also on the SSA forums just go to manufacturer forums and go to sundown audio. Sundownz is Jacob Fuller, the owner of sundown audio, obviously a good resource. Jacob knows his stuff and is great to work with.
