bobonit
Need an opinion on batteries to support my Sundown amps.
I'm working my way through building my system and I'm starting to think I might not want to go with the 2 Kinetik HC2400's I was originally going to put in the trunk due to space restrictions. I have a Kinetik HC1800 under the hood, DCPowerinc 250a alt with 14.6/15.6 switchable MLA installed. I need enough juice to power 3 SAX-100.4D amps at 4ohms and 1 SAZ-3000D at 1ohm.
So, keeping the power under the hood the same, would it be ok instead of 2 HC2400's in the trunk to go with the smaller HC600's (maybe 4 or 6 of them)? I could easily fit those anywhere and still have some cargo area left over.
You can do it that way. I'd buy a few first, test it out and watch your voltage. Buy more as needed. :)
Good tip, thanks.
I'd get two Deka Intimidator 9A31s instead of Kinetiks :)
But... you could do several smaller batteries if needed, yes.
