high_score_1
fi bl rms?
im new too buying fi subs and i have my 2 full loaded bl 12's.
i have the cooling, and flatwind options.
what amp and how much power should i run to them total? :huh:
they'll be in 4 cuf box and tuned to 32 hz
power is not a porblem ill buy batteries and alternators i need
Go with Sundown, they are really well known around the forum and all you here is great things about them....im hoping to get one soon.
What coil configuration did you get Dual 1 or Dual 2? Also their rated at 1000rms but could do a little extra due to them being underrated. IMO you have about 2500rms to play with safely. I cant recommend you anything without knowing what ohms they are.
Edit: 1000 bucks for the amp? You have a huge selection to choose from, and since you have a 1 ohm final load you could look for an amp that does about 2000-2500rms at 1 ohm. If you wait a tad longer you could get the new SAZ2000D coming out. But if it was me I would get a 3000D since their going for cheap right now, just but gentle on the setting and set it with a DMM and you will be fine.
Edited by Enellz
dual 1 :P
audioque aq2200 $389, sundown saz3000d or saz2000d not yet out,
x2 on the AQ
