doverman454
Help with wiring
So I recently just ordered my two powermaster 925's 220amp alt and 0 gauge wiring kit.
My question is how do I wire the new alt to the current bat I have now and from the one under the hood to the rear 2 Powermasters then into the amp? Reply's will be greatly appreciated!
Thanks,
Dover
Connect positive to positive to positive (parallel) and negative to negative to negative etc.
Parallel will give combined current at same voltage.
Series will give you combined voltage at same current.
