I'll be running a sundown 1200D and a sundown 100.4D to a Fi BL 12'' and a set of hertz HSK 165's
Going in a 1998 Dodge Ram 1500.
Big 3 will be done
The battery that I have now is a Autocraft Silver.. It says on the top something like crank amps at 32 degrees is 935
The alternator that's on there is this:
Think I'll be good, or should I get a yellowtop to put under the hood?
Yeah, I haven't installed yet so I don't know if it'll drop bad or not...
Should I just get 1 yellowtop under the hood or what?
My truck has an empty slot to put another battery on the other side above the right wheel...
Should I just pick up another autocraft or would it be better to run just 1 yellowtop
You might not even need another battery or anything..
Just hook everything up and see what your voltage is at then decide..
Instead of buying a yellow tip now and later you dont even need it..
Im just telling you what I would do..
I found a powermaster D5100 for 170 shipped
Max amps: 1600
Ah: 60
Jump on it?
Where'd you find it? If you don't jump on it, I will....... immediately.
Edit: after looking at the specs, that's not really that great.... my local parts supplier got me a dual post 825cca battery with a 110 ah capacity...... for $85.
I was thinking the 3100 series.
Edited by BigDaddy13440
