NB50
Bromos Build Log
Vehicle 1999 Pontiac Grand Prix
Electrical = Big 3, 2 runs of kicker 1/0, 1 stock battery up front and 1 Deka Intimidator 9A31 in the trunk. Possibly HO alternator.
Head unit = Pioneer DEH - P880PRS using active. Using KnuKoncepts Krystal RCAs (need to purchase cables)
Tweeters and amp = SEAS Prestige 27TFFNC/G powered by a USAcoustics 2200F (need to purchase tweeters)
Mids and amp = Mach 5 Audio MLI-65 powered by a USAcoustics 2300F
Subwoofers and amp = 2 Incriminator Audio Flatlyne 12's each in their own 1.2ft^3 box powered by a Sundown Audio Prototype amp
Raammat Sound Deadening (still need to purchase)
Electrical is done
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageTL032.jpg
Head unit is in.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall007.jpg
Box just about done just need to carpet, router edges, and cut holes.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageABCBox008.jpg
Box all done with carpet.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall003.jpg
Test fitting wood for a false floor.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall004.jpg
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall005.jpg
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall006.jpg
False floor carpeted and done.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall009.jpg
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall010.jpg
Testing Box fitment.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall011.jpg
Tidying up wires a bit.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall012.jpg
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall013.jpg
Subs are in and hooked up working. Just need to adjust settings.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageInstall014.jpg
Damn looks good man.
How are you liking those flatlynes?
Thanks.
I just got them in today. I only got to listen to them for like 15mins and still need to tune it.
Looking Good!! I am looking into the SEAS tweeters for my truck.
Thanks guys. I have heard a couple people (who's opinions are respected) that run them with the Mach5's and speak well of the combo.
Went on a little spending spree the last couple days, these are just the things directly pertaining to the install. Also got Loudspeaker Design Cookbook, t-shirt, and a digital caliper.
I got nearly everything, just need to get deadening yet.
100Ft 14/2 covered speaker wire.
3 Knu Krystal RCAs
2 40A fuses & 2 60A fuses
2 Seas 27tffnc/g tweeters with mounts
Streetwires fused distribution block
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imagejunk010.jpg
I have those same RCA's and tweets.:)
I wanna see more pics of this amp and the specs.
What amp?
These are all the amp I will use at the moment.
From the top 2200f, 2300f, prototype.
Rated 200X2, 300X2, 1400X1.
This weekend.
Got the door panels off, heres what I have to work with.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageMids004.jpg
Made a template for the mount started cutting the mount when the jigsaw I was using attacked me. Seems the fan broke on the inside and one of the fan blades shot at me.
didn't go any farther then the shirt though.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageMids011.jpg
Test fitting clearances.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageMids009.jpg
Trimming up door panel to allow for clearance.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageMids012.jpg
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageMids014.jpg
All done.
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageMids016.jpg
img-resized.png Reduced: 82% of original size [ 1024 x 768 ] - Click to view full imageMids015.jpg
Got all wiring done and amps installed. Still need to make temporary mounts for tweeters to play with positions, then final mounts, and to tune it. Still need to order deadening also.
Looks nice, Bromo. It's been a long time coming! :)
Progress is looking good. :fing34:
After looking at some build logs I saw someone using a PVC cap as a tweeter mount. I've decided to take the idea as I dont want to take the time and money to do the fiberglass I was originally thinking of. So I went to the hardware store picked up the supplies, and after $5 and 10min I had this.
Still need to hit them with some paint and then mount them.
With a tweeter mounted in one.
Painted and installed.
Got to do a little bit of tuning with the time alignment, and wow themusic has so much more depth it is like it is three dimensional.
That is a cool mounting idea. Looks good!!
Cool idea on the pvc! Install on the tweets looks great!
Thanks guys, I can't take credit for it though as I pulled it from a build log on another forum. I need to figure a way to tighten up the passenger side though as I drilled the hole a little big and it keeps tilting down. I put a nut on it but cant get it tight enough, was thinking about trying to hit it with some hot glue.
Maybe you could try a rubber oring.
That could work in conjunction with the nut that is on it, but the nut adds some depth to it and it is hitting the a pillar and pushing out the panel a little bit. If I could find a different nut that might work, hmm might be time to stroll around the hardware store. Thanks.:fing34:
You could take the nut to a belt sander and make it thinner, to keep it from hitting the pillar.
pretty cool
