wof131s
Would I Need BP Power?
I have US Amp's MD.3D amp (2000 watts output), would it be necessary to add BP Power for this setup? Or will i be ok? Is there a differance in SQ or sound output without BP Power?
For what subs and how many?
My bad man, guess that would help. lol
Two "Q" 15 subs are the subs that i wanna run. So would this be necessary?
Thanks a lot for the input man. Is there anyone else that feel the same way about these subs?
It never hurts to have a little headroom as you may upgrade later.
I know those amps, and no you won't need it. If you had something around 1500wrms per sub I would defo look at the the BP option. Make sure things are scoped clean and they'll be fine
BILTD or anyone that have experience with this amp,Ive got another question. I got a HO alternator from Nations that push out around 140 Amps at idle and 230 Amps max output. I also have a 2 Farad cap and a battery that is 1000 cranking amps (CA)and 850 CCA. Will this be enough to run this amp without it going into PROTECT or shutting off due to the lack of "juice"?
