mikek
enclosure help for rf
my friend wants me to build him a box for 2 12" rf p1's. right now hes using a pre fab box that is complete garbage. its for his dodge daytona, which is a hatchback, any tips on what size sounds good, or what airspace sounds good for a ported box, or if sealed sounds better with those, because i have no idea. thank you very much
What does RF suggest for those drivers?
From the Rockford Fosgate website...
Description
Size 12"
Impedance 4-Ohm
Power Handling 150 Watts RMS
300 Watts Max
Voice Coil Diameter 1.5" 6-Layer
(3.81 cm)
Motor Size 40 oz.
Speaker Connector Dual 10 AWG compression
SPL (1w/1m) 86 dB
Mounting Depth 5.875 in.
(14.92 cm)
Shipping Weight 12.50 Lbs.
(5.67 Kg.)
Rec. Sealed Enclosure 1.02 cu. ft. (28.88 liters)
Range: 0.70 cu. ft. - 1.80 cu. ft.
Range: (19.82 liters - 50.97 liters)
Rec. Vented Enclosure 1.79 cu. ft. (50.69 liters)
Vented Tuning Frequency 36 Hz
Port: (1) 3" diam. x 6" long
Port: (1) 7.62 cm x 15.24 cm
I would use the ported specs.
Good luck!
