NB50
Calculating QTC of an enclosure
I would like to know what is the most accurate way to calculate QTC of a sealed enclosure.
For example in WinISD i have the specs for my speaker in there and in a 1.2ft^3 it gives me a QTC of .704
In BBP6 with a 1.2ft^3 enclosure it gives me a QTC of .56
And Calculating it from the formulas on these two sites.
http://www.diysubwoofers.org/sld/sealed1.htm
http://www.carstereo.com/help/Articles.cfm?id=29
They give me a QTC of .62 with a 1.2ft^3 enclosure.
So I would like to know which way is right?
That is the same result that I got from the links I gave. Appears the formulas are from the Loudspeaker Design Cookbook. Guess I will use that from now on.
I wonder how WinISD and BBP6 calculates them and why they are different?
BBP6 has an option to use normal ecuations or ecuations that take into account fill. I suspect that's why it gives skewed results.
Not sure on why winisd works bad.
I have used the "Speaker Enclosure Calculations" portion of bcae1.com in the past.
Opps should have mentioned that is turned off when the calculations were made.
Heres screen shots.
WinISD
BBP6 (Just noticed Xmax was wrong but that doesn't matter)
Calculated
Edited by bromo
