dirtyduce62
box for 18" btl
whats up guys. i need to figure out some dimensions for the btl 18" sub so i can fit it in my 1962 chevy belair. any adice would be greatly appreciated
we cant help you much with out more info. give us your max deminsions, what what your goals are etc...
my hight- 13" width-53" and depth-28". i need to know what size my port should be. im gonna run the btl 18 with an autotek ss1900.1d wiring it to 1 ohm. its gonna be a daily system but yet i want it to hit pretty hard
my cubic feet will be 9.08. i need to know all the dimeansions for my port.
i also need to know what would be the beast hz to tune it to.
Use your max dimensions. I am assuming sub up, port rearward.
Double the top plate (1.5" thick), use 3/4" everywhere else. That makes the internal dimensions 10.75" x 51.5" x 26.5".
Due to the depth of the box, and the depth of the sub, you can make a port on the rear of the box up one of the sidewalls. Make it 10.75" x 8". Run it into the box 19.25" (that should make it 8" from the opposite wall).
That leaves around 6.8 ft^3 tuned to 32 Hz.
Brian
Brian
I swear you're one of the most helpful people lol
The specs BKOLFO gave you sound good, hope you post pics of your install.
THE AUTOTEK AMP IM RUNNIN WILL BE WIRED AT RMS 1900 @ 1 OHM WITH THE DUAL 2 OHM BTL. WITH THE BOX DESIGN WILL IT BE A GOOD SETUP?
