Smallk07
Fi BL help
Not strip your holes next time? :lol: Try bolts.
i didnt strip the holes i was wondering is there any type of glue i can use to put on the screws
Loctite would work, or a dab of Titebond II.
More to the point though, if your screws are coming out, the construction was pretty poor, or you're using he wrong type of screws.
You probably have a ton of problems with your enslosure construction if this is an issue.
For a quick fix used 1/4-20 hex head capsrews and T-nuts or hurricane nuts. I am not sure on that subwoofer's basket, if the holes won't accomadate 1/4-20, go with 10-24. Stay away from 10-32, as you will more than likely cross-thread one of them...
I still would wonder about box construction though...
If You Have A Quick Release Box Plate Or A Plexi Window, I'd Opt For Bolts.
i had problems with my snaping.... your saying yours are backing out?
