4X4AUTIGER
Q vs. SSD
Alright either want 1 10" Q with BP Power or 1 12" SSD with BP Power and either the copper or flatwind cable... How many watts should each handle and which one should i go with? I want more of an SQ setup but i also want people to hear me coming down the block when i feel like turning it up.
... i would go with a 12"Q @1000W,2cubes,30-36Hz ...
nothings coming up on the search... and i have a f150 so i cant fit the 12" Q... So either 10" Q with BP power or 12" SSD with Bp power and either copper or flatwind coil
... so i cant fit the 12" Q... So either 10" Q with BP power or 12" SSD ...
i have a Ford F150. the sub is going under my back seat. i am getting a seat lift so i can fit a sub with 6.5-7 in. mounting depth... The 12" Q has 7 in mounting depth while the 10" Q and 12" SSD have 6.5 in... i want to give myself some air space
maybe u should look into some 8s(a pair) ... like SUNDOWN AUDIO E8,...
BL 12" with pole champfer. You will blow dust caps off if you don't.
BL 12's are 6.75" deep.
Yeah but they require a ported box. so they wont fit. trust me ive already talked to alot of f150 people and they said either 10" Q or 12" SSD
