wof131s
Q Enclosure
Is a 2.9-3.0 cuft.(after all displacements) to small of a ported enclosure for the Fi Q?
it would be great for a 12 and it would still work for a 15 on the small side but it would work. what is the box tuned to though i wouldnt put it in a box tune much higher than 32.
Am using two 15s but in to seperate cambers that size. But would it be better to use a single or a dual camber. I was told that the single would hit harder. What do you guys think? The box is tune to 30Hz using a port that is 2 X 14 and 16.75 inches long. Am still in da building stages so i can change some things just alittle if its necessary.
Edited by wof131s
