sandsnip3r
amp settings
what should i set the Sub sonic at if its a 15" FI BTL Ported at about 33Hz
ive heard 23 and ive heard 33..
and what the funk do i set the phase to? 0-180 degrees
Just play with the phase until it blends the best with your mids. I'd put the subsonic around 20.
low pass filter setting depends on how well your sub can play the higher bass frequencies and how low your mids can go. Generally I like to keep it somewhere between 60 and 80.
Subsonic should be one octave below your tuning point. Low Pass filter will depend on where the sub can blend with your front stage. Leave the phasing at 0, or play with it like KU40 suggested.
So what exactly does the phase do?
i would leave it at 0... easiest thing to do... but low pass filter should usally stay below 80hrz and subsonic i would throw it aroun 28hrz depending on how much power and how well your subs hand the lower bass below ur tunning frquency... just play around with them to you find a happy spot... :wacky:
changes the sound wave's timing. If you look at two sine waves on an o-scope and they are 180 degrees out of phase, they will cross the reference line at the same point, but one will be going up after that point and the other will be going down. The peak of one sine wave will correspond to the valley of the other sine wave. Waves that are 0 degrees out of phase will lie on top of each other. Then if you move up from 0 degrees, one sine wave will start drifting sideways from the other. They will cross the x-axis a little farther apart with each increase in phase shift. Then you hit 180 and they're total opposites. Then as you go higher, up to 360, they start moving back together again.
Tried to explain that as simply as possible, hope the visual still got through.
That's Normally What I Do. Sub On 80hz Low And Midrange Woofers On 80hz High.
Easier To Leave The SSF At 0, Or You Can Fack With It A Bit To Get Better Mixture.
