kegann
Help me decide what to get
Alright Ive heard nothing but good things about you guys, and going to start saving up for my system and plan it out now. I have a 1993 camaro. Now my biggest dilema is my trunk, they are fudgeed in camaros.. I want a system with a little of box SPL and LOUD SOUND QUALITY... I want it to hit pretty damn hard and hit lows...but I also want decent sound quality. My choice right now is either between 2 12 BLS or Q's...
Now if I can find anyone to build me a box or give me a design with dimensions for a camaro trunk ill go ported. But for now im stuck buying a box from these guys which only come sealed with 1.0ft per sub for 12s.
http://www.subthump.com/acamarowell.htm
And what I currently have chosen to run with these are
http://www.woofersetc.com/index.cfm?fuseac...Product_ID=1078
http://www.woofersetc.com/index.cfm?fuseac...Product_ID=4464
1 extra battery and big 3 upgrade
http://www.kinetikaudio.com/hc1400.asp
2 of these(1 per sub)
http://www.audioque.com/aq/AQamps2200D.htm
So help me decide guys
if you plan on going sealed, you need the Q's
Well thats the thing, I would like to go ported, but I need to find a design/dimensions for a 93-xx camaro trunk if i want to. Also,depending on the reviews I get of the Q'S i might just go ported.
Do you think I would be satisfied with 2 12Q'S in a sealed box? I want it to beat pretty damn hard and still have good sound quality. It will be a daily driver but I prob will never max it out besides every once in a while.
Also you are right it seems.
1 ohm power 2200 x 1
So if I got 2 QS thatd be 1100watts per sub at 1ohm right? I would only need 2 of those if I got BLs
Go with the sealed setup. It will be pretty loud, I had 2 12's sealed in a 90 firebird (Not the same I know but has similar trunk and hatch design) they had some good output.
i wouldnt recommend running bl's on 2200rms IF you get them, since their still 1000rms subs.
it sounds like the Q's are for you
Is this your first system? what other subs/amps have you had
go out and measure it...?
go get depthxwidthxheight and ill design something real quick for you..
Edited by sandsnip3r
Wow im a tard, i ment BTLS but I wont be getting those so im fine. This is my 2nd system, first system I paid 600 bucks for 2 10s and a chitty ass amp in a s10 truck years ago...(which suprisingly beat good for 600 bucks). But I guess ill be going with the Q's
Also sniper, I know how to measure but your missing the point. Heres an idea how my trunk looks cept this model is one behind my camaro.
http://www.cardomain.com/ride/2303185
But ill get some measurements for you and would love for ya to give me a design
o ok. anyways 2 Q's sealed sounds good, but if someone can design you a ported enclosure then go with it
To the OP - I'm running two 15" Qs ported and they get very loud... my box is 7cuft tuned to 32Hz. Have Chris at Fisher Customs sketch you up a box design for $25 :)
Edited by CadillacMatt
x2 :clap:
