Diforce
Hybrid clarus dimensions help
I would like to build a pair of homr bookshelf speakers using the Hybrid Clarus 6/5 set , But i cant find the dimensions of the drivers anywhere .
For instance how much cubic ft is required for the woofers ... etc ..
Do you think it would be a good idea ? plz help :)
I really don't get it what kind of respectable manufacturer like Hybrid audio does not submit driver information ...
Midrange speakers are normally infinite baffle. Please do not come on here and put down companies.
So you want me to buy a set of speakers for 500 bucks and guess ? ... Normally is not good enough m8 , what the hell is " normally " ?
I need driver information ... Q factors , etc .. the works ... Why is it not published ?
:) that's funny ..
:) that's funny ..
I suggest you loose the attitude.
[email protected]
most people dont publish that info man, dynaudio doesnt even do it. If you call scott i am pretty sure he can help you out. btw calm down a little man, we are all about helping people out.
:) that's funny ..
Hybrid drivers are designed for in car use primarily. Why would people who use them in car need those measurements?
You sir, are in the 1% of people who will use the drivers outside of their intended purpose. Certainly someone as resourceful as yourself can find this page and figure out what needs to be done once there.
The way I see it is if you dont like the fact you cant find info on a product to use it for something that it was not designed for and you feel the need to bitch about it. Then dont use it. That's pretty simple.
If you want to use it for something that it was not designed for that is fine but it is trial and error on your part.
Edited by AlpineAndy
i use home theater drivers for cars before i used hybrid.
So have I, but this is the other way around.
i believe kicker did something with their ss components one time for display purposes. had them in a bookshelf cabinet.
