the mange
730 watts - severe dimming - which of these batteries should i get?
I have one run of 4g to my 730wrms amp, with big three done in 4g, but I'm still dimming really badly. im almost positive its my batt, but i haven't tested my alt yet.. anyway, which of these batteries should i get (to replace stock batt):
kinetik hc 1400 - ah:60
amps: 1500
kinetik hc 800 -- ah:36
amps: 950
or something else that will hopefully solve my dimming problem? i dont know much about batts, any advice would really be appreciated. thanks to all.
Is this going to be your starting battery/only battery? Also, have you looked into Powermaster?
thats weird...i have 1000 watts and my lights dont dimm at all...but anyways you should try powermaster battery's
i get dimming off 800 but my batt is going out lol... time for a new one
haha..WOW!..800?..sure do need a new batt..
id say go with a bigger alternator
Yeah this will be my starting/only battery. my alt is 120a so i'd imagine it will get the job done with only 600 watts. how many amps do you think i should get in the new batt? and what does the ah rating mean? i like powermaster's prices btw thanks
Get your battery checked and replace it. I have 1000 watts in my car, with a (small) stock battery and a 90 amp alternator.
AH=Amp Hours
now that i think about it, would it make more sense to wire a second smaller battery that would just power the amp alone? i have plenty of cranking power, so should i just get another cell in the trunk? how many amps would i be looking at for a 600 rms amp?
~60 amps. The more the better though.
:lifevest:/!\ NOOB ALERT /!\ :lifevest:
My lights dimmed. Got a capacitor! Stock electric... Idle is 14.9 volts and when running never drop below 14.5... Capacitor helped me a lot in my case. It isn't nearly the same w/o it. Took it out for a while and my voltage suffered... I'll get flamed for mentioning it, but it really worked for me and I got the voltage to prove it... :)
huge ass cap^^
check the link i listed before. good battery cheap price. also with an alt that big even without a batt id dont think you should get dimming. i have a 140alt stock amp and a yellow top running 1200w and not a bit of dimming even at full tilt at idle. your alt is probably going or you have a bad wire in your charging system. if you dont properly charge a battery it will kill it so get it checked.
