rushnrun
HTS Center Channel... speaker arrangement?
Quick question on a center channel..
Basically looking for opinions due to personal experience.. What will sound better, or will it make much of a difference
Whats the reasoning for having two tweeters? If it was me personally I'd run one tweeter flanked on each side by 2 of the 5.25's.
If you are dead set on using two tweeters, I'd put them as close together as possible to reduce comb filtering issues.
This is the first time I'll be using dual tweets... I usually run two woofers and one tweet (for towers)... I was just trying to make a larger center channel to handle a bit more power and have more output to better match with my larger towers..
*Fairly new in the Home theater building.... I've built several towers with good results... this is my first center..
