T0mmysee
RE XXX component set
I was wondering if anyone has had any experience with these. Pros? Cons?
Are they worth the money? If not what would you recommend. I listen to mostly, hip hop, electronic, and funk.
All opinions will be appreciated :D
I have been running a set for about a year now being powered off a DLS A3 receiving 270wrms per side.
Pro's
-Midbass monsters
-Very defined and tonal
-Tweeters not harsh at all
-Excellent Xover's provided
-Extra power doesnt seem to affect them at all
-One set manages to keep up with a 145db set up.
Con's
-Motor is absolutely huge and will require custom housing in most cars
Other than that I cant say a bad word about them.
Hope that helps.
only two bad thing are: the tweeter and midbass are night and day. like they werent meant for each other. like the midbass will be strong but weak highs.
and other thing is the 4" mounting depth that the midbass has.
but they do sound good. but dont feed them over 200 watts. :/
Edited by SouthPole1989
