lamchop_8
What amp is better and more efficent for this sub??
I'm buying a 18'' Fi.BTL,Daily,d2,cooling,hixm coil,induct heat ring and I want to know which amp is better between these to?
(1) !!!NEW!!! AudioQue (AQ3500D):700 Shipped
http://www.audioque.com/aq/AQ3500D.htm
http://www.audioque.com/aq/images/AQ3500D/AQ3500Dguts.jpg
OR
(1) Sundown (SAZ300D):[REFURBISHED] BY:DB-R (720 Shipped)
(Comes With)
.Original Box
.Bass Remote
.Copy Of Owners
.Warranty Card
.1-Year Warranty (From Db-r Electronics)
Specs
http://www.sundownaudio.com/3000d.html
http://www.db-r.com/sell/store/images2/ra/...-3000D-04lg.jpg
Which amp should I choose???
BTW:Everyone tells me to pick the Sundown amp instead of the Audioque but the Audioque puts out 3500 rms and the Sundown puts out 3000 rms will the Sundown put out more than 3000 rms or what?Also both amps say 300 external amp fuse are'nt included so how am I supposed to use the amp?Also were do I buy the 300 amp fuses from. I'm open for any answers I apperciate any help.
saz 3000d is rated 3000 watts @1 ohm @ 12.4 volts...
how many volts is the "other one" rated at
You should go read the stickies in the Sundown section and then tell us which amp puts out more power lol.
Must you ask the same question over and over? It is a bit repetitive.
