crimson229
How it's for a ported box?
Box is for a FI BL 12 in a Dodge Stratus. I went with a 28Hz tuning for more SQ over SPL. Please share your thoughts
Port Type: 4" Flared Port
Port Tuning: 28 Hz
Number of Ports: 1
Net Internal Volume: 2.5 cubic feet
Port Volume: 0.0066 cubic feet
Subwoofer Displacement: 0.1500 cubic feet per subwoofer
Total Internal Volume: 2.6566 cubic feet
Number of Terminal Cups: 1 per subwoofer
Front Baffle: Single-Layer Front Baffle - 3/4" Thick
Box Dimensions:
22.625" (w) x 20.125" (d) x 13.75" (h)
not bad but id use more port area like 2 4" or just do a slot port with like 30in of port area it will need to be 36in long.
What year Stratus?
think about what Fi recommends. scott recommends 12-16 sq. inches per cube, just like most of the sub companies out there.
you have 5 per, you have too little port, and you'll definately have PORT NOISE.
I don't know how you got the port volume to be 0.0066 cubic feet, but it's wrong. It has to be more than that.
Port displacement has to be ATLEAST .09 cubic feet or so
with a 2.656 cubic foot box and one 4" areo port you'd need a length of 12.75 to get a 28hz tuning
so.. pi x r^2 x Length
3.14x4x12.75=160.14cubic inches
which converts to .09267 cubic feet 160.14/1728
And as everyone else has stated, run atleast one 6" or 2-4" ports
the only issue is you're box will have to be slightly larger and the two ports will have to be roughly 29" long
