vettonator
IB3 Lineup
I'm glad to see that the IB3 subs have finally been added to the site. I love that 30mm x-max. They should really get some air moving.
Will there ever be a 10" version available? Three 10's would fit perfectly where I want to install them. I might be able to do three 12's, but the install would be a lot trickier as I only have an opening of 12"x 32", so if I go with three 12's, Ill have to mount a 13"x 38" baffle behind a 12"x 32" opening.
How much clearance is required in front of the IB312 at full excursion? I'll need to know how far it will have to be spaced back for clearance at full mechanical excursion before I can determine whether or not I have enough clearance on the back side of the baffle. Thanks.
Edited by vettonator /aka boomstang
