lamchop_8
What would be the best tuning for my setup?
I'm upgrading from fully a loaded bl to fully loaded btl (d2)
This is my (Soon To Come) setup is it good or not?
SUB:(1) 18'' Fi.BTL (Fully Loaded)
AMP:(1) AudioQue 3500D (3500 Rms @ 1 Ohm!! & BTL's are recommended @ 2000 Rms) [is the amp good or what?]
its getting the whole 3500 rms
http://www.audioque.com/aq/AQ3500D.htm
http://www.audioque.com/aq/images/AQ3500D/AQ3500Dguts.jpg
(4) Screws for terminals (Better solid connection no leaks)
Enclosure:(1) [Ported] 6 Cuft. (After displacemant) Tuned to 32hz. maybe 3/4 MDF
Thats my setup but my main question is how much of a db differnce is a enclosure thats tuned to 32hz. from a enclosure thats tuned to 34hz. I love loud music but I want it to get deep as well (I'm not spl just daily) so whats best?
For A lucky quess do you think I'll hit @ leats 149db's if tuned to 34hz.
Do you think I should get removable ports like 27hz,32 hz,33hz,35hz, or dont do that just keep a regular port?
P.S:This is my budget so please dont ask for anything more expensive
do you like the LOWS on music?
yes the aq 3500 will put out 3500rms, and theres no telling how loud youll be,youll have to see once you get it setup. 32hz should be fine.
Yes I love lows that shake my car but I would still want to be in the late late 140's to early 150's. I've seen people with one sub that hits 150db (Not SPL Daily) so its not impossible it just depends on the setup. I just wish I could have both you know? so should I get removable ports or what?
If it was you would you recommend removalbe ports so you can find out what you like best or what? Because mainly somedays I'll want to listen to low notes 27hz. port,Then if I want regular music 32-33hz or hi notes 35hz.
699
Edited by RobClay
32hz will get low also. if you want to do multiple ports go for it
Edited by RobClay
Good god how much does that amp cost?
Both of your testicles. :shrug:
I like 18s @ 28Hz
