david in germany
Reccomended enclosure size for SD-1v2 10"
Ok I searched and couldn't find a thread about the 10" SD-1v2's can anyone give me a suggested enclosure size for a single one sealed?
I will be running it with my SAE-1000 at 8ohms if I get it.. Thanks!!
David
Edited by david in germany
David
0.75 sealed. I would run it @ 2 ohms not 8...
wo aus deutschland biste?
Not from Germany but in Germany ;) Aber jetz im Mannheim.
Ich arbeite im Wiesbaden.
P-Dizzle, Thanks! but will it be ok with 600w Rms?
Yeah. A little headroom won't hurt. I would run the sub in the 0.6-0.8 cuft range.
cool, i'm from Gruendstadt if you know that (between k-town and mannheim)
now with tye and me that's 3 ppl over here i know using sundown
I drive by Gruenstadt almost every Sunday on the way to Kaiserslautern.
Sometimes the wife and I go to Globus there because we don't have crap in Mannheim.
Yes, I have the SAE 1000 waiting for my MINI to arrive. I have a BL 10 I was going to use but it needs too much airspace for the MINI and my other option is a RE SE 10 but I just found the SD-1 for cheap. :)
What are you running?
just a mb quart system in the front
rebuilding the system over the winter
sax 50.4 for highs and mids
sax 125.2 for sundown e8 as midbass
2x 3000d on 2 re sx15 (changing them to nightshade 15 after christmas hopefully)
atleast i hope i can make the order on the sax amps and e8's this month
Sounds good! My Celica is running MB Quart in the front, Rockford 6.5's in the rear, 2 FI audio X series 12 in IB and a 25 to life Power 1000 powering everything. I love the SQ!
The mini will be stock for now except for the SD-1v2 and the SAE-1000. The mini stock boost system has a flat response down to about 60hz so the single 10 should blend well with it. :)
Got the sub today. :bigclap: Seems like a very solid little woofer. What can I expect for power handling in the .75f3^ enclosure? should I polyfill? I have time to get this all worked out as my car will be built next week and it will not arrive till the end of the month.
Thanks all once again.
David
