Travo-18
Mayhem or BTL 12"
Im currently wanting to try something new and I was wanting to know what would be a better choice.. I have 2 5000rms amps for each 12" woofer I intend on using. So Im wanting to a setup with 2 12's and its between the AA Mayhem or the Fi BTL 12".. I dont have any dealers of AA in my area and it don't seem like they do much of the speaker customizing like Fi does... So whats everyones input?
BTL 12" vs. Mayhem 12"?
You could wait for those new SMD woofers >:D
Yeah.. I was thinkin about those as well.. But Steve said the 12" models would be a little while longer than the 15" and 18".. I want to only do 12's
Do you have a budget or space constraints? I think (4) 10's with 1000+ would be awesome. Or maybe (3) 12's but then the final load would be weird.
Yeah, I do remember reading that now that you mentioned it.
EDIT: I would go with the Mayhem's. Seems everyone has BTL's.
Edited by abxx
I dont have BTLs :D
I dont have BTLs :D
:lol: Me either.
has anyone used both yet?
Edited by caligreen
They are basically the same thing.
Wrong!
would you please stand on the difference between them ?
totally different motors would be a good place to start?
BTL12
DUAL 1 | DUAL 2
Fs: 39.3 Hz | 37.9 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.09 | 5.28
Qes: .21 | .20
Qts: .20 | .19
Mms: 206g | 222g
Sd: 480cm^2 | 480cm^2
Vas: 25.7 l | 25.7 l
Spl: 90.5dB 1W/1m | 90.3dB 1W/1m
Bl: 18.3 N/A | 27.2 N/A
Xmax: 28mm * | 28mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 1.75-3cuft | 1.75-3cuft
Sub OD: 12.500
BTL12
DUAL 1 | DUAL 2
Qms: 5.09 | 5.28
Qes: .21 | .20
Qts: .20 | .19
Mms: 206g | 222g
Sub OD: 12.500
I have used both -
BTL = motor is single larger diameter slug
Mayhem = triple stacked motor
(4) BTL's were 0.7 dB louder vs. mayhems with the same box, same amps, but I did not measure actual power to see if the amps were making more power with the BTL's (Maybe slightly different impedance in the box).
Mayhems seem to sound a little smoother. . .
Brian
