slam
Sundown sax-100.4
I know the sax-100.4 can handle 10-16v but what about a lil above that. lets say from 17-18v. Im trying to run my whole system all on 16v eliminating the extra 1/0 wire running from under the hood and adding to the 16v charging system. thanx in advance
well 17-18 volt is a 16 volts charging system
as 14 volt is a charge for a 12 volt system
as far as it application to the sax 100.4 i have no idea.
I understand that but on the manual it say 10-16v. I just dont want to burn up. Thanx
just did a lil research common sense and on the saz-3000d. it says Operating Voltage : DC 10V~18V and on the 100.4 it say Operating Voltage : DC 10V~16V. so im assuming my answer is a no
Correct, it will not like 17-18 volts.
You can add a Kinetik Tri-Post battery and run it off the 12v post - thats one easy way to do it.
Nice Opti 2500 by the way. The '96 series built by Lanzar were some of my favorite amps in the mid 90's. I still have a 2500, a 4150 and a 6200.
thanx. I love their old stuff
another question:
I received my sax-100.4 and turned it on only to notice engine noise coming out of channels 3 & 4. Some other ppl told me they had the same problem. Is there a fix for this without sending it in? I did a search and didnt find nething thanx
Edited by money_inc
another question:
I received my saz-100.4 and turned it on only to notice engine noise coming out of channels 3 & 4. Some other ppl told me they had the same problem. Is there a fix for this without sending it in? I did a search and didnt find nething thanx
Hit it with a hammer a few times! :P If that doesn't work then send it in, I doubt it is anything you could fix, I imagine Jake could though! :shrug:
Hmmm, shure it's not those speakers? Any power cable running with your 3-4 channel interconnects?
i have 2 sets of hsk165's... how would it be my speakers neways? i swapped out amps and bam. this amp has it and the other dont. this is for a comp vehicle so everything is done properly..... and no its not on my 16v setup
Where did you get your 100.4 ?
it was a used amp from another member of a board
Might have a solder joint issue on the crossover sub-card. DB-R can fix this pretty quickly.
Thanx for your quick reponse. I believe this is one of the reasons everyone talks so highly of sundown..... Great Customer Sevice!!!
I called db-r about another amp and told me they can get to it in dec lol
Sundown items are a top priority - Chris should be able to get to it quickly.
WOW! thanx again
If Chris determines it is a warranty issue we will cover the repair bill - just put a note in there for him to contact me about this repair.
sound great thanx
