sundownz
Sundown E8 Pre-Order #2
Is it possible to make 2 single 2 ohm?
Not without custom order coils. Would be pretty expensive.
Like how much? I just got a 100.4 and I want another one, use 2 channels for these 8's and the others for my rear deck.
You could try 4 ohm stereo - they will sound pretty good with that power level.
Really won't be worth the cost for custom coils.
Could I bridge two channels and wire them parallel for 2 ohms?
No you cannot bridge it at 2 ohms, it will not be reliable for the long term.
Okay then, nevermind. Back to the drawing board!
Jacob, could you price 6 and 8 of these and send it to my email. [email protected]
Also when is this presale ending?
Josh
ETA is November 21st. Give or take...I think
Edited by Duran
Whip out a calculator boy! $360 for 6 and $480 for 8. I did that in my head, cause I passed 4th grade.
Have you also been a douche since 4th grade? :) haha yea I didn't really see the price thing I was in a hurry earlier. What is a calculator anyway?
Don't take this seriously dur.
C'mon man, can't sense any sarcasm? I was laying it on pretty thick.
are there any problems with coil rock, because of the tall profile surround, and the single spider arrangement?
Nope.
Full T/S specs are listed above - including the 200 RMS rating.
They will play up to ~200 Hz or so clean - so they will work as a midbass. We have two installed in a Bronco here for midbass and they do GREAT IB for that job :)
THAT is what i wanted to hear.
What Mid speakers are you using? My Omnes BB3.01 only go down to ~400hz and would 2 of those be good with a 125.2, or should i go 100.4 and bridge to 2 channel?
Edited by Biggy
What Mid tweeters are you using? My Omnes BB3.01 only go down to ~400hz and would 2 of those be good with a 125.2, or should i go 100.4 and bridge to 2 channel?
He is using Eminence 8s for midrange and Selenium tweeters up top.
Two would work well with a 125.2 -- this is what the Bronco has (100.2 actually).
So two of these would work great under the rear seat of a explorer sportrac, correct. Running off a 125.2, with subs facing forward.
ya the 125.2 would work if ran on each channel you wont want to bridge it tho
Edited by loudcav
I wouldnt use the 125.2 since the E8s are only single 4 ohm you could use the 100.4 and bridge 2 sets of channels to each woofer
I talked to Jake about that and he told me it wouldn't be reliable to run them like that.
Run (4) 8's off a 125.2 @ 4 ohms bridged and call it a day. :)
Edited by P-Dizzle
expect my payment for 2 8's, 125.2 and 50.4 in the next 2-3weeks
Good Taste! I just placed the same order except with 4 8's for the wife's Armada ;)
Indeed - for two subs on a 125.2 you would need to run 4 ohm stereo or 8 ohms bridged. Either way is actually plenty of power for the E8s :)
