JoshM20
Amp Clipping
What the hell is an O Scope?
What ohm load are you running?
1ohm
34.6 Target voltage on the 1200D @ 1ohm.
Thx, So I keep the gain at this or turn it back a tad once i found the voltage?
MCM carries them too. Cool little gadgets but too spendy for most. Scope
Yea that is a little much for me. Not bad if you installed systems or had other work uses for it. :)
The voltage will stay fairly steady. The 1200D is underrated so you should be good with anything from 34-38 VAC.
that they are but if your running a ton of power its a tool like a DMM and Clamp meter that you should have. Ive still gotta pick up a clamp meter and a true RMS DMM one of these days
Project Van, 2000 Tweeters, Sup? =x
Dizzle, What does it mean when some ppl talk about head units and they say 2v or 4v or 5v output?
its the output voltage the radio gives through the rca wires. The amp also has an input voltage range, something like .2v to 6v. the higher your rca voltage. the less gain you need on the amp
It is the maximum output voltage the radio provides through the RCA outputs.
Correction.
