mrray13
Welcome to the IHoP
I forget you are in Texas and will be your own country soon. I gotta watch what I say here in the land of the north.
If that happens I'm turning my wagons north. Ain't nobody got no time fo' any of dat buuullshit.
my cell reception blow in my bedroom.. and some other places around .. i use my cell for work and its a must it stays with bars....
has any one ever used somthing like this? do they work?
http://www.ebay.com/itm/Internal-Cell-Phone-Antenna-Signal-Reception-Booster-Smartphone-Tablet-Pager-/320978043077?pt=PDA_Accessories&hash=item4abbc840c5
They don't work.
http://www.ebay.com/...=item4abbc840c5
That circuit design is the exact same design back when cell phones were pretty much new on the market.
For THOSE phones, yea they worked for them.
Now, for the seller selling them on ebay, he should be sued or reported to ebay for false advertising because NO smartphone on this planet would benefit from those whatsoever.
It's a different ball game with different technology now.
IT's the provider's fault for not having a tower or enough trafficked bandwidth capable in certain areas.
I have plenty of issues with trafficked areas where i live and it irritates the hell out of me.
towers are good in my area.. its just in my bed i get poor reseption.. and in the hill country.. i guess im just assed out while in bed.......
All yeast infection possibilities aside. Do want.
It reminds me of one of my fave pick up lines.
"You are so fine I want to pour milk over you and make you part of my complete breakfast"
MMMMmmmmmm mmmmmmMmmmm
watching Beverly Hills Cop, so damn funny.. I love older Eddie Murphy movies.
The super cop story was goin really well
Jonny Wishbone
LoL
Play on playa!
Playa'in on.
How long are you down there? Was just cursing you durring breakfast for being an ass and in warm sunshine. Met some fam out and my bones didn't want to work.
It's effing cold.
Come back tomorrow. It's only 82 atm. Overcast. Sitting by the pool staring at the beach, eye candy, and being brought top shelf drinks free :)
I'm going to be staring at some ass later.
Bring back some warm for us and I will give you all my snow.
new sub from dayton. looks nice
http://www.parts-exp...ign=email010313
Sure does.
Attractive, but curious as to why they use only a 2 layer, 2.5" coil. Large enclosure suggestions for the car audio crowd.
Low power handling, keep the weight down, reduce inductance. No need for a big coil if big powerhandling and motor strength is not the goal. I know they suggest a ported cabinet, but with such a high total q and low resonance, I would say it is more of a sealed design driver. While no Bl is listed, I bet it is not a really strong motor.
Frankly, I like the looks of it. This might be a really solid design for the 4 way IB manifold I have thought about putting in my attic.
Am doing big3 and works best to go from battery to alt and alt to amp. I don't see why that wouldn't work but would like input from someone?
I would hook it at the battery. The alt will have too much demand if you hook it right at the alt. It is best to feed from the reserve of the battery, and allow the ECU to make it's calculations based on the battery readings. In many cases there are inductive probes inline on the feed wires from the battery to the alt. So it is best to avoid linking downstream of the battery.
But he is doing the big 3 so I can't see any difference if connected to either.
The inductive probes read current. If you pull amplifier current from a charging stud on an alt it pulls reserve current to the alt through the inductive probe.
Burp your system and amp clamp the power wire to the amp. Next, burp the system and run the amp clamp between the alt and battery. Get back to me with the results wink.png. Even running the big 3 you have the current load increased exponentially through the main alt feed if you attach the amp power to the alternator on the factory line. You can almost think of battery reserve as a shock absorber.
I still can't understand how with the proper gauge and length wires done for the big 3, there will be a difference between connecting to the battery or the alternator. How will there be any difference when it's like one big continuous wire and it's just either of the sources connected first then second? With the big 3 added to the picture I see it as a singular wire that all the power is passing through. Both the alternator and the battery are on that wire. At which end you attach the wire that goes into your amp is no different than the other. If you connect to the battery it's just like you used an extension that connects to the alternator.
The battery acts as a buffer/filter if you will. It will keep voltage and current steady. It can suuplt instant current as needed, where as if you hook it directly to the alt, you are asking the alt to do this job. The alt will then ramp up current and keep it there.
Ask yourself why the manufacturers hook there fuse panels to the battery versus the alt.
Indeed.
No, bud. I am not pulling my pants down.
Boston's layout looks familiar to cities here...
