mrray13
Welcome to the IHoP
I like the manners stock that looks like the McMillon. Beaver tail/paddle with a vertical grip. The vertical grip that is close to the trigger helps you get better trigger squeeze.
Even a bigger deal in semi auto rifles IMHO.
One of these?
T25 screws, rather
'98 Suburban, '97 K1500 and '98 C1500 all had clips. Hell both the Hyundais have clips too.
Drove the Elantra through sandstorms for 3 days and the filter is fucking pristine
and it only took 5 seconds to check the filter, not 2 minutes
based on my quick underhood inspection that was the only thing that wasn't hex, yeeesh
On the topi cof throttle bodies, when I pulled the one off my truck I was a dumbass and didn't depressureize the coolant and burned my hand when I accidently pulled the line off.
It shouldn't have been pressurized with the car off. The degas bottle should bleed all the pressure off.
It wasn't full pressure, but there was some head behind it when I pulled the hose off, ~140* coolant came shooting out at my hand with me perched up on the grill guard. Resulted in a stream of pleasant words.
There is one withougb that thumb strap on the top Stefan. I'm on my cell. I'll link it later.
I think McMillon calls it the A5???
I'll find it for ya.
Must be this:
They also have a version without the thumbhole.
If I went that route, I may go for the B&C:
Rifle was suppose to show up on Monday, and Tuesday at the latest. Didn't show up on either. Now it was suppose to show up today--nope!
There is a reason stocks that look the same are different prices... I'd be tempted to go with a Whiskey 3.
Yes I know. A big price difference would also be from the dbm feature on the manner.
The whisky 3 is also a chasis system I think. Manners makes one too.
Sako TRG is by far the best rifle stock combo from a factory. So anything that emulates that would probably make me happy.
When you guys started to talk about stocks I was trying to figure out what investing slang you were using.
:lol:
"No no no, this shit doesn't make any sense."
I can't stop thinking about beef stew.
Main problem of the Sako is parts are almost non existant and if found expensive as hell I do believe.
Every joint in my body is so sore.
Every joint in my pocket is bent.
or would be if there were actually any there
Joint savers! Never crush another joint.
Comes in cone and straight
It could work either way.
