ElusiveJustin
Fi SSD 15" motor
And the problem is? We need more info. But, if the motor is damaged, might be wise to let it go.
Must have gotten dropped, we've never had one of those break before...
Is the slug cracked?
it wont line up? You didnt drop it? you were driving when it happened? were you in an accident? lol j/k Sounds like you need to have the pros look at it? Did the coil come unraveled?
When you push on the cone is there a scraping noise? Or is there no movement at all? Check your tinsels too.
If it wont move at all then it is seized up!!!!
doesnt this usually happen when the sub has been bottomed out alot?
More like it being overdriven for a long preiod of time....overheating and/or unraveling the voice coil at the same time.....then it will lock up....
Sounds like you clipped the amp and burned the coil up and locked it up.
We've NEVER had a motor fall apart...the glue that we use to put them together is stupid strong.
That picture shows us nothing since you took it at an angle.
when you click the picture, it comes up larger and you can see it then. and can i ask how in the world did you do that to that sub? lol
That was definitely dropped.
Send that thing back in ASAP!
Fi Car Audio
Attn: Warranty Dept
5480 Cameron St #108
Las Vegas NV 89118
Please be sure to include a sheet of paper with your name, address, email, and phone on it as well as what coil was in it (D1 D2). We will get it taken care of ASAP.
Thanks,
Scott
material failure ?? and u pulled the coil out .. just fine ? hm....
