Xibalba
re port/box calculator
i am new to building boxes and would like to know, about how accurate is the re box tool? I made a pretty nice little box tuned to 35 HZ and have no clue how accurate this tool is, so it would be good to know beforehand.
thanks
thanks
I would get your tuning frequency and box volume from a different calculator and then just use the dimensions from the calculator you used onto the RE calculator to print out the cut sheet. The cut sheet is pretty much the most resourceful thing on there. I know SSA has a calculator (sorry to lazy to get the link while at school). The RE calculator sets your your frequency and i believe your box volume lower than it should be.
