billystorms24
How good is this amp?
Hey guys whats up i was wondering if you guys could give me some input on this amp Id be running it .5 ohm. what is another brand that is comparable to lanzar? Please let me know i might buy one if its good. and what gauge wire is needed to run it with a 180 amp fuse?
Thanks guys
Billy
if u mean good as in rated power, it's just a hair shy of doin what it is rated at, if u give it just an itty bitty push of clipping, it will definitely do rated power.
Tested do to around 1947w @0.5 ohms, rated to do 2kw at 0.5 ohms to let u kow, 80% efficient.
if u buy from qualitycaraudio.com, you'll get full 3yr warranty through lanzar.
If u dont, then go to squaretrade and get your warranty through them for 2 yrs.
Use at least 1/0 gauge power wire
lanzar sucks but the opti line is decent there are a few other companys using the same boards as the opti's for the money its not bad better than a hifonic bxi2006
