forgot .8 ohm @25 hz
ohms rise from there..
roughly .8 - 1 ohm from 25 to 40hz
1.5 ohm @45hz
2.7 ohm @50hz
3.2 ohm @55hz
1.9ohm @60hz
so basically capable of 2700watts at two ohm... with a better power supply the rest of the readings should/could be much higher...
1.5 cubes tuned 35
I've burped that sub off 5k in that box... did mid-high 140's in my Mazda 6 at the headrest (meca)... but only for a burp.. the dust cap came loose on it so now it just rattles around inside the woofer..
*** I need to point out that my last results the 25 an 30 hz readings belong under run 2
high output @ 35 hz 12.5v input 2 ohm (accounting for impedence rise)
was....
1820 watts... not bad at two ohm for a .5ohm stable amp.... also note that it'll handle 17v input.
**that post was suppose to read "not accounting for impedence rise"
