jonbearsmt
ready to go active>?
alright... so i dont have back speakers any longer... . and long ago a few guys here jimjm5 im not gonna name names told me to drop my rear fill.
well now i have a sexy sundown 4 channel and and my front is in need of a filling sound.
i listen to rap.... so sq is funny for my goals right... but lets talk about it.
im gonna get some http://cgi.ebay.com/6x8-5x7-to-6-Speaker-A...1742.m153.l1262
and some deadener....
open to ideas.
You may as well make those adapter mounts yourself, out of MDF.
You'll have to use the Head unit's HPF to help with the crossover duties along with the 100.4's onboard ones. Unless you decide you want to use an external crossover. Or if you want to get a head unit capable of 2-way.
And after you decide that, what's your budget? :D
A better baffle really helps your midbass, don't skimp on those little plastic things build something out of mdf.
I still have the template for the 5x7 to 6.5" adapters I made, if you can wait until this weekend I could take the flush trim bit and make another set.
jim that would be very helpful. as im not a wood worker.
budget is around 300
im pretty sure my h/u has all filters needed for what i need to do its a pioneer avh dvd 5700
Considering this is your first shot and midbass will help you a lot. I'd use the Seas CA18RNX. $150 or so for the pair and it will leave you with more than plenty to get a variety of great tweeters to go with them. What sort of mounting space and location do you have for the tweets?
currenty this is the spot my tweets are in
im not sure where would be a better place.
where is the best place to find those seas
thats a big fuggin tweeter compaired to what im used to and im not sure if i have depth for that...
im really not sure if i have depth for the 7 inch seas.
but this is a big choice....
and im not gonna spend 450 bucks for that prosseser.
I thought that headunit had high and low pass crossovers built in to it? I know mine does and it's the P-5900ib
that processor can be had for less than $450..here ya go bigjon
http://www.sonicelectronix.com/item_2835_P...+DEQ-P8000.html
ok ok its cheaper but is it a must!.... like i said i listen to rap...
so SQ is not really in the music... i just want a good warm sound. my h/u has mucho settings and shit on it.
The Sundown can take care of what you need.
Smaller depth mid = less midbass. They do make the CA18RLY for that purpose, but I'd try damn hard to fit in the RNX.
There are smaller tweeters, but I was spending your budget :) If you have to go small, the Seas Neo is hard to beat when you are on a limited budget.
honestly dude, if rap is all you truly listen to then I wouldn't even bother. i probably would just get a nice comp set and the midbass and call it a day.
well show me what you think will work please. i look alot but i have never heard nor seen any for my self.
Pioneer all the way.....at least in terms of midbass + tweets :)
hey bigjohn you like your type rs? mebbe upgrade to type x's? JL makes some nice comps, I listen to rap(screw) most of the time and my Orions keep up fine, (I know I coud have done better), what is your spending limit? 150? You like the really high highs? Or a super clean sound?
maybe someone can chime in about the comps..the only comp set that i've had was the alpine type x 5.25's. sounded decent but i know it's better out there. try looking toward cdt, pg, or boston. the last time i heard a boston comp set it sounded good to my ears but that was awhile ago and i don't know if they are still on top of their game.
edit:forget cdt i forgot about the $300 budget
Edited by nickeveready
It does, if you want to use passively crossed speakers, for this application however, it won't work... well, it will, but he'll have to use the amp crossovers.
Nothing wrong with wanting to sound better. And tbh, there is no passive comp set that will be better than running active.
At least.. without spending $1k on a set of Dynaudio 360's.
And you have experience with these? Perhaps in your backpack? :(
If you can't name a decent comp set why do you think it would be better than say the CA18RNX I recommended? On top of that the X 5.25's would be terrible for the application, and the CDT's are way overpriced junk.
While there is more hassle with an active setup, in his budget even with just the amp crossovers (which are FAR from ideal) the HDS/CA18 combination will compete with passive sets costing 5x as much. Your comments recommending otherwise are not based on any real experience :(
and that is what im asking for real experiences......
the type R's were fine for a year or so... but as i age my taste grow.
i have alot of money in my lows stage... and now its time to spend a lil on the rest. now more then ever seems how i do not have any rear fill.
i must check depth before even thinking about the 7 inch...... if my OEM speaker location was at the bottom of the door i would have more of a chance.. but its in the center... it would be sweet to run a 7 inch mid and a 1 inch tweet active.
Does Hybrid count? :D
As far as "mainstream" ones go, they're out there of course, but the value is so skewed to DIY it's absurd. Alpine's F1 stuff is great, yeah, but I'd rather have the unbadged SS drivers themselves. Even the Polk SR's probably do pretty well, but a Vifa ring radiator and midbass are a lot less expensive at Madisound and you don't get passive Xovers that'll be useless to you.
m5, your recommendation is fine as a matter of fact that's the route i would go. but he clearly stated that the only music he listens to is rap nothing else, and on top of that he didn't want to spend any additional money on processing, that it why i made the recommendation i did.
