Totalnewbie007
Thought I'd share this with you guys
What happened to the IB?
The spiders became unglued on 12 of 16 woofers, pulled them all out and fixed them, then sealed it so that wouldn't happen so easily next time.
I've also wanted to put more power to them >:), so sealing it should help.
Would be interested in hearing that.
When I get another 3000D, and my component stage done, and most of the beauty work done I'll probably start going to florida shows around here, and maybe make a trip up towards South Carolina. However it will be some time before I get around to that.
no vids?
Did some more work on the doors,
This rain is killing me, so I've been trying to sand, but I'm wet-sanding whether or not I like it. Sucks because I was hoping to get a lot done today. It's been a constant drizzle since I woke up. GERRRRRRR....
So I started with 150, but it was going slow, then I switched to 40/60 to knock that crap down! When my sand paper started wearing out prematurely I switched to a little bit of hand sanding with some medium grit sanding sponges, but more was coming off the sponges than my work!
So here I am drying off inside :)
there are some areas that I just need a dab of filler, but it's wet out and I'm not going to try to apply filler until it clears up.
I'll see if I can start on my a-pillars after a little break.
So I got some work done on my a-pillars, I will be able to finished them, however I don't have paint for plastic, and I'm not sure if I want to paint or vinyl them to match the doors.
They will have to be black or a dark color because the tweeter is black.
Edited by Rawr-dq
WoW... you could be featured in a Popular Science Magazine article! :D Absolutely insane!
