nickeveready
AudioControl EQS for active
Lots of wasted bands of equalization with that processor installed after the crossover. Consider that every band below a HPF and above a LPF is not doing anything and it should quickly become apparent that there isn't a lot of use for that processor in a high end system using active processing. It has its place, but not in a 3-way active system.
so what are some good processors out there that can handle the job? as far as alpine goes the only option i have with them is the Imprint(pxa-h100)
Edited by nickeveready
The imprint is a big joke. If you want an Alpine processor, get the H701.
don't think it's compatible with the ida-x100..i really want to get that hu
If you want to run active and are putting in a screen up front, you should really do the H701 but yes you will need the 205/505. Time to make the choice, a nice active install or that headunit. Sure you could still buy a H701 and a RUX to control it, but that seems rather stupid considering you don't have the screen yet.
the ida-x100 is the ipod hu not a screen, though it does have a screen on it. but i see what you mean
The H100 can do a 2-way + sub setup. I'm not sure how you can control it completely.
