xhilr8n
Subwoofer Choices
Well earlier this year i had a crossfire vr2000@1ohm around 3kw on a dd 9515g in a Pete K. designed t-line. I really like the output through a broad range of frequencies, and plan to do another t-line setup. However i think i could have made a better choice for woofers
I have a 2006 nissan frontier (the bigger ones), have quite a bit of room if neccessary. Undecided on an amp to power it but will be at least 3kw with proper alt and batts. I have installed two sets of PG RSD6.5 comps with 100 watts per channel still running passive for now. i think the two sets of comps ran active would almost keep up with the system i have in mind. The plan is to do another t-line but with a woofer better suited for that kind of enclosure. There are a couple factors i am taking into consideration
1. X-max
2. Rms in said enclosure
3. Sound Quality (an eclipse ti 15 outdid the dd in the same box by far.
4. I want it stupid loud, would like to break a 50(i know what it's hard)
I think i am thinking in the right terms on this one, but i am welcoming and seeking GOOD advice from people with experience in similar situations
Forgot to add, i want 2 12"s or 1 15<-----more than likely the single 15
ps.....the dd died twice, probably my fault but it wouldn't do what i wanted it to so it didn't matter.
thanks for help in advance
Jason
I am looking into the following subs over the next couple weeks before i purchase one.
DC level 5
Mach 5 spl
Sundown nightshade(isn't this the same as the old btl)
FI BTL
Eclipse 9115(found one new in box) for 600$ 4hp motor at my local shop
