kippo
Kenwood KVT-819 DVD won't playback video
hi,
I just got a Kenwood DVD player with monitor (KVT-819 DVD) and when i tested it, i do get the sound but the screen is not showing any video. It is still at the playback menu but i see no buttons to press to show the movie.
anyone familiar with Kenwood DVD player?
thanks.
i have d owners manual but the pictures in the book is not the same as the screen display.
also when d monitor comes out, how much will it go back in when it settle for playback? all the way in or half-way?
thanks
i think it plays while all the way in..
as well as u can play video with it tilted or all the way out.
go ack to the manual and read the video source select part
The video source button switches in the following order each time u press it..
BUilt in disc
TV
Video
IPOD
Rear Camera
Navigation
You can also turn off the video by holding the button for more than 1 sec.
When you press the button again the previous screen comes back up.
Do you have the parking brake trigger connected or did you bypass it?
d parking brake connection is not connected. Does it have any interlock to video playback? how do i bypass it?
thx
yea theres ur problem, it has to be grounded...
i think to bypass the newer units u have to ground it to a switch and click on, off, on, or something to that effect
when u said that the parking brake connection to be grounded, i would assume it is to negative terminal?
FYI, the unit is not in my car yet. I just use my test bench to check if everything is ok first.
