KING
Help Again!
Ok i am bout to purchase my first audio system. but i had a quick question. Is it really neccesery to purchase Component speakers and a Amp for them. Or can i just use my Manufacture speaker.... If i Just use my manu facture speakers. Do i Just run them to my head unit or wat
If you're looking for undistorted output in any meaningful way, yes.
lincoln factory speakers are very nice... i think it depends on the type of car (spreakers).... unless your a SQ head... then,.... ill shut muh mouf
Depends on your goals, likes, skill level, and ultimately, budget.
Just having better drivers doesn't mean it will sound better. You will hear a common phrase used; "it's all in the install." Heed this information as it can make or break your entire system.
To me, it is always worth it. Heck, even if you get just a small 40x2 amplifier, and some passive components from a major name (Cadence or Kicker for example) and do just a little sound deadening on the door while you have the door panel off to install the new speakers, the difference would be pretty solid. :)
