appleyard
Need more midbass, 8"?
I want moar midbass on my front. Currently I have the Alpine SPX177A powered by RF T4004. I was thinking of going for a pair of 8" for my mids. Can anyone recommend me a pair for under $200 - 250. Also it can be 7" as long as it can play low and has good midbass.
I have 2 15Q on my subs and when I play full tilt, all I can hear is rattle and no mids.
Thanks
Do they have to be 8's? The Mach5 MLI should give you what you want.
Midbass monsters if applied correctly. I am using them in 4 vehicles.
How and where are your midbass installed now? That has just as much effect on midbass output as the drivers :)
Currently mid are mounted on the stock door location.
Why 8"? Hmm I guess bigger is better. Was thinking of the March5 mli as well. Does it have a good mid bass and can go low as well?
If applied properly, oh yes.
add more sound deadening to your door..... that should help with the midbass, especially of you don't have any
That's a pretty broad statement. Mass loading a panel doesn't always increase midbass response favorably.
would you elaborate on the term properly?
Also what xover point and what power did you run yours?
thanks
