streetbeater07
Questions about BL 15
Ok right now I have the Q 15's and I've gotten used to them so I want to upgrade to the BL series. My question is, ok i want the same freqency response as the Q's have cause I like how they perform down low, but I need to know which options in the BL should I go with to have a good daily woofer? I was thinking of going with the cooling, flatwind, daily, and universal options because I am not looking to do any competing just some really bad street beating. But Im a little skeptical about the cooling option because it says that there is less metal in the motor thus making it a little weaker? So should I just go with p/chamfer, flatwind, daily, and universal because I dont want anything to break in the driver. Or do i even need the flatwind coil option because it makes it more prone to "peaking"?i dont want any peaking just low hz bass. Please help someone, thanks alot in advance
the universal is just a great option if you plan to change your number of subs in your one amp set up...
also i got it only incase i wanted to resale the subs and whom ever bought them wished to change the ohm's on them....
first step is coming up with a price.... keep in mind you say thay need to be reconed... so its realy only the vaule of the basket and motor at this time.
