krazzyboy44
possibly four 15's
can possibly pull this off? i have a 1975 caprice with a HUUUGE trunk
it is possible.... but you need to ask a more direct question....
you posted in FI topics..... so are you asking if you can fit 4 FI 15s in a truck.. . and what series fi subs are you asking about
65"W x 17"H x 35"D
now that i really think anout it i dont think four 15's would fit properly so im going with
with three 15's. im talking about the BTL's how much power should i run to them daily? i was thinking about running
three of them off a 40.1 i saw multiple times that they was benched at 7000+ with a good electrical or just try to find
three zx2500's. any other suggestions? for power i spend up to $2600 on amp(s)
this not my car here but its the exact same year and model...
Edited by krazzyboy44
You'll probably end up spending more in your electrical system than anything.....depends on what all options you get in the btl's and exactly what are you wanting to do? spl? if not spl then you dont need the btl's. maybe look into the bl series or the q's.
Go to the FI technical section where all their drivers are listed along with the options and recommended uses for each, decide which one you like and read thoroughly about all the options available for each driver, then decide from there which one is best suited for you and come back after you've narrowed it down a little, and someone could be a lot more help to you....The Q's are the sound quality reference line and they pound hard and sound damn good at it, the bl series are geared a little more towards spl and "fill the gap" between the btl and the q's, and also sound decent to boot. I wont be the one to make this decision for you and then you not like the outcome, so do a little R&D and hit us back up.
you can not ruin 4 btls in that trunk no.
I figured that after i thought about it
think more along the lines of the SSD's or Q's
