vanquish
HELP...
Got a few questions about my setup before i order everything so help would be appreciated.
In order to prevent further displacement I'm considering adding a baffle to the outside of the enclosure.
- Will this be a sufficient amount of support for the sub vs a baffle on the interior?
- When using Psp.com's calculator for aeroports it asks to input "Volume of Box in Cubic Feet" is this before or after all displacements?
- Can someone provide a link for instructions or a diagram on how i am supposed to wire under hood batter>trunk battery>amps
- How should i wire the (2)saz1500's to (2)FI BL Dual 1
looking to get the whole 1500w to each sub individually?
- Suggest a budget trunk battery under $200 that'll be good for this particular setup. Not looking to buy multiple batteries just have space and funds for ONE.
Thanks in advance.
Thanks in advance.
  1. Yes, a baffle on the outside of the box is fine
  2. It wants the interior of the box, after all displacements. The calculator already takes into account the minimal space the tube takes up.
  3. Front battery +---Fuse------------Fuse---Rear battery +----(fuses)---Amps
  4. You ordered the wrong Voice coils on your subs. Should have gotten Dual 2. The best you can do without voiding the Sundown warranty is either run each amp on one sub at 2 ohms. Or strap them both and run them at 4 ohms.
  5. Deka Intimidator 9A31. If you're apart of realm of excursion forums, there is a group buy going on in the classifieds section for the Deka's.
