lee
how do you determine tuning frequency?
I know how to get port area in square inches, but how do I find out the port length and tuned frequency? I need to know the math to aquire my goals. cant find anything on this specifically, only port area which i already know
Solving For Length of Vent or Port
Note
k values:
vent has one free end and one flanged = 0.732
vent has two free ends = 0.614
vent has two flanged ends = 0.850
Where
Lv = length of port or vent
Dv = diameter of port or vent
Dmin = minimum diameter of port or vent
Np = number of ports or vents
Vb = volume of box
fb or Fb = tuning frequency
k = end correction factor
Sd = surface area of subwoofer
Vd = driver displacement volume
Xmax = maximum linear displacement of driver
Important to note that "flanged" and "flared" are not even remotely the same. Flanged means that the end of the port is flush with a flat surface like an outside face of the box, whereas a free end is just the port sticking out into space like the open end of a PVC port inside a box withnothing around it. Flared means that there is a flare (like the bell on a trumpet) on one or both ends of the port. There are equations for that as well and they are somewhere in this forum. I built a fairly simple Excel spreadsheet for flared port calcs that DevilDriver hosted somewhere. Again there should be a link in that thread.
IF you find that link please post it, I can add it to my bookmarks.
http://www.soundground.ca/index/flared_port_calc.xls
there it is... :rockwoot:
:boobs2:
That's the one. Nothing pretty but it works.
So if Dv = the diameter of the port or vent, how would you measure this given a square port? Sorry if this additional question is redundant.
convert from a rectangle port to a circle port with equivalent area
Thank you sir! I think I have got it. :D
